Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Truck coyote Vs Mustang coyote
    Sep 2009
    Williamsburg, Ohio
    382
    So I am picking up a truck coyote this weekend. Finally found one with low miles and a good price. Something that might be worth posting is the differences in the 2 engines.
    I believe the big differences that I am aware of are the
    Cams (Cant remember if its intake or both intake and exhaust)
    Intake Manifold
    and I believe there is something a little different in the timing cover.
    I also believe the earlier mustang engines had the piston oil jets and the trucks do not, but also read that the later mustangs did away with the jets, I cannot confirm this however.
    I am sure Mike has some good input on this.
    2011 F150 FX4 SCREW EB
    1997 Cobra Coyote Swap w/IRS project in progress slowly....
    89 Mustang SSP 5.0 Turbo -Gone
    03 SVT Focus Turbo -Gone
    Sardinia
    2,287
    Exhaust cams are different, different front cover, manifold I believe is the same just a different color, 10.5 to 1 compression on the truck 11 to 1 on the Mustang.
    2006 Mustang GT "Shirley" sold 11.37
    2011 Mustang GT "Ashley" Bone stock?
    Dec 2009
    Springboro Ohio
    686
    If you need an alternator for the swap I have one with 300 miles on it.
    Sep 2009
    Williamsburg, Ohio
    382
    What alternator do you have?
    Sent from my SM-N910V using Tapatalk
    Dec 2004
    Sardinia
    7,876
    oooo so a drivetrain mock up coming soon??
    Sep 2009
    Williamsburg, Ohio
    382
    Quote Originally Posted by Stangman View Post
    Exactly....minor change of plans. Doing all my mock up before paint.
    8,829
    This is gonna be sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
    Sep 2009
    Williamsburg, Ohio
    382
    Hopefully. ..but there's a slight chance Jesse will have all his piles up and going before I finish mine.
  9. #9
    Dec 2009
    Springboro Ohio
    686
    Quote Originally Posted by egbertnr View Post
    It is off a 2015 f150. Had to change it for a bigger alternator to run a snow plow.
  10. #10
    Sep 2009
    Williamsburg, Ohio
    382
    Ah...I'm getting an alternator with this engine but I think I need to a different one that works with the brackets for a fox swap. I've seen these things but have confirmed what I need since I had not planned for this route but getting a truck engine for a good deal so I had to jump at it.
  11. #11
    Dec 2009
    Springboro Ohio
    686
    Well if for some reason you need it, it will be here.
  12. #12
    Sep 2009
    Williamsburg, Ohio
    382
    good deal, thanks
  13. #13
    Dec 2004
    Sardinia
    7,876
    Not likely. I cant build em with monopoly money and my dashing good looks alone lol
  14. #14
    6,281
    Intakes are the same, just lack the rubber biskets to mount the engine cover. Intake cams are the difference, exhaust is the same. Compression is 10 to 1 last I checked. Oil squirters were by year, my 11's have it the 12's do not, but my 12 mustang engine had them. 12/13 they changed head studs, so there are 11mm and 12mm head studs, different lengths as well. Timing cover is a little different, lacking an idler pulley. Won't make a difference unless you are bolting a blower to it. Oil pans are different than the mustangs. Suggest using a canton drag race or road race swap pan. We have the drag race pans. Rods are the same as 4.6 rods, same with rod bearings. Main bearings are a special number but I'm hearing a 5.0 crank will set down into a 4.6 block, haven't tried it personally yet. Hope this helps.
  15. #15
    Sardinia
    2,287
    Sorry Egbert it is intake cams that are different. Truck motor should be 10.5:1. Another thing I forgot to mention are oil pump gears are supposedly thinner.
  16. #16
    Sep 2009
    Williamsburg, Ohio
    382
    Quote Originally Posted by firestang70 View Post
    I've heard that too about the oil pump gears. My question is can they be swapped without other changes to the billet gears? And I knew Mike would clear us up on all the details.
  17. #17
    Jun 2007
    604
    Yes oil pumps are different, you can put a mustang pump but have to do the whole thing can't just change the gears, but why not just get the billet truck gears? They will work fine
    "Si vis pacem, para bellum - If you want peace, prepare for war."
    "Revenge is not a valid motive, it's an emotional response. No, not vengeance. But instead, Punishment."
  18. #18
    6,281
    I sell triangle speed gears, they make a truck specific gear set. Lower volume of oil means more hp. They aren't much thinner at all. Hard to tell the difference really.
  19. #19
    Sep 2009
    Williamsburg, Ohio
    382
    I didn't know they made truck specific gears...good to know.
  20. #20
    Sep 2009
    Williamsburg, Ohio
    382
    I talked with TSS earlier in the year and they may not be making anymore F150 gears. They claim they are not a big seller...however Mike may disagree with that. I ended up buying a Ford Racing Boss oil pump assembly. I have a source that told me Ford uses TSS gears in their Boss oil pumps.
