Page 6 of 19 FirstFirst ... 234567891016 ... LastLast
Results 101 to 120 of 375
Thread: Kwik92GT's How NOT to build a Project Car Thread
  1. #101
    Independence,KY
    6,584
    Im not a big gt fan either and I think it looks killer. Makes me wanna mini tub my car
  2. #102
    Dec 2008
    851
    That thing would look better under a tarp in the back yard. I will compliment you at a later date, just not feeling it today.
    Quote Originally Posted by 89notch View Post
    I can tell you I don't have any time to commit here anymore. I have no problem stepping aside and letting someone else have my spot. I also don't have a problem bringing back banned members.
    xtremeoutlawseries.com
  3. #103
    Feb 2006
    Williamsburg, Ohio
    1,183
    Killer looking car and an awesome build!
    The Bad Boy!
  4. #104
    Jan 2005
    Dayton
    1,301
    car looks awesome Greg
  5. #105
    May 2006
    usa
    479
    The car looks absolutely freakin' killer Greg!!
    Peace
    James
    1990 ssp black coupe (aka ROCKET), bone stock CI unported E7's plus full mac exhaust, water pump and crank pullies, synthetic fluids, 14 degrees of timing, 80 mm maf, power pipe, 65 mm throttle body, 4.10 gear, welds and skinnies plus suspension. Best et to date 12.41, best mph to date 106.58 with a best 60ft of 1.59 on 26/8.5/15 Mickey Thompson slicks on a 64 degree day with 35% humidity all with 260rwhp and 320rwtq
  6. #106
    Thanks for the compliments. Should have some more progress pics up in a few weeks.
  7. #107
    Looks great Greg, I saw it at Jason's and it was looking better each time I saw it. He got it straightened out and looking killer. Any updates lately?
  8. #108
    Thanks Mike, no big updates right now, had to make some room in the garage first. Should have some real updates in 3-4 weeks.
  9. #109
    Sep 2011
    733
    I got a 90gt and was thinking about mini tub about how much did it cost anyways the car looks awsome
  10. #110
    Thought I'd throw a quick pic up with it sitting on all 4 wheels. Finally off the jack stands and on its own suspension. Actual progress pics will follow fairly soon. Sorry about it not being a pic in the sun but it's all I have right now.
    Bad lookin mofo right there!
  11. #111
    Thanks, really appreciate it.
  12. #112
    Nov 2005
    springfield
    1,119
    that looks badass!
    when a stroker windsor just wont do
  13. #113
    Well, got the holidays out of the way and my garage back in order so I'm finally getting some work done again. Going to start this phase by getting the brakes done and then who knows from there.
    A few of the pieces I have going in:
    Racecraft manual conversion
    Skinny Kid brake line kit
    Maximum Motorsports manual brake pedal kit
    Ran into a potential problem when putting the master cylinder in. I bought the Racecraft kit because they make the smallest adapter that I know of and the master cylinder sits REAL close to the header. Need to figure out something about it, I'm not liking how close it is. I have a different master cylinder that gives me almost 1/2" more clearance but I really want to use the Strange master. Even with the 1/2" more clearance it's still too close IMO. Nothing is ever easy with these things.
  14. #114
    Dec 2008
    851
    That will self clearance.
  15. #115
    Figure I'll throw up a few before and afters of the rear hatch area etc.:
    BEFORE
    AFTER
    BEFORE
    AFTER
    BEFORE
    AFTER
  16. #116
    Quote Originally Posted by evil8 View Post
    Uh huh.
    Anyone know the boiling point of brake fluid?
  17. #117
    A few of my rear coil relocation kit finished:
  18. #118
    May 2006
    usa
    479
    Looks wicked Greg!, as you already know that's some top notch quality work you've just posted up!
    Peace
    James
  19. #119
    Dec 2008
    851
    So is that gonna make it out in 2012 Greg?
  20. #120
    1,307
    Brake fluid is subjected to very high temperatures, especially in the wheel cylinders of drum brakes and disk brake calipers. It must have a high boiling point to avoid vaporizing in the lines. This vaporization is a problem because vapor is compressible and negates hydraulic fluid transfer of braking force.
    Quality standards refer to a brake fluid's "dry" and "wet" boiling points. Wet boiling point, which is usually much lower (although above most normal service temperatures), refers to the fluid's boiling point after absorbing a certain amount of moisture. This is several (single digit) percent, varying from formulation to formulation. Glycol-ether/dot three/dot four/dot five point one brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the atmosphere under normal humidity levels. Non-hygroscopic fluids (e.g. silicone/DOT 5-based formulations), are hydrophobic, and can maintain an acceptable boiling point over the fluid's service life, although at the cost of potential phase separation/water pooling and freezing/boiling in the system over time - the main reason single phase hygroscopic fluids are used.
    Boiling points for common braking fluids [1]
    ..........Dry boiling point ... Wet boiling point
    DOT 3 .. 205 °C (401 °F) ... 140 °C (284 °F)
    DOT 4 .. 230 °C (446 °F) ... 155 °C (311 °F)
    DOT 5 .. 260 °C (500 °F) ... 180 °C (356 °F)
    DOT 5.1 .. 270 °C (518 °F) ... 190 °C (374 °F)
There are currently 6 users browsing this thread. (0 members and 6 guests)
