Page 46 of 59 FirstFirst ... 3642434445464748495056 ... LastLast
Results 901 to 920 of 1171
Thread: 91 Mini Tubbed Mustang Coupe
  1. #901
    8,845
    Just out of curiosity what kind of side load does that setup place on the crank and associated bearings and seals? How much tension will be on the belts or is that why you are running a timing belt that can be run with little to no tension on it?
  2. #902
    Jul 2016
    81
    I run sliders on my kirksey with no problems. Bracketed to my cage and isn't going anywhere
  3. #903
    The pump itself will have little to no tension on it.
  4. #904
    8,845
    Quote Originally Posted by 2Fast4You View Post
    So how is the pump regulated? What pressure differential will you attempt to maintain or is it preset based on engine displacement and RPM when you order the unit? I understand the concept just curious at what point too much vacuum is too much and starts to hamper the upward stroke of the piston cycle. In my mind too much vacuum effect on the piston up stroke would be like sticking your finger over the end of a syringe (without the needle in it) and trying to pull up the plunger. Thanks in advance for the 411.
  5. #905
    It has a built in adjustable regulator, you are correct about it being preset from them based as you mentioned. I believe we are anticipating 15" vacuum.
    Sent from my Z965 using Tapatalk
  6. #906
    8,845
    Would be fun to see it on the dyno and make a few pulls at different vacuum settings to see the effects.
  7. #907
    Yes it would have, unfortunately I wasn't in the position to acquire it before hand.
  8. #908
    I'm sure there would be a way to measure crankcase pressures to test its effectiveness as well, any ideas?
  9. #909
    8,845
    You could T in a vacuum gauge on the bottom end where the vacuum pump will be connected to the lower side. A mechanical version may work, but not sure being the atmosphere will likely be heavy with oil vapor and mist. Another option would be to obtain an electrical vacuum gauge but you're looking at $250 for the only model I could find. A vacuum boost gauge that reads vacuum down to 30inches would also work. They are a bit more reasonable as they are in higher demand with regard to one with a sending unit vice the mechanical option if you have to go that route.
  10. #910
    I will contact the smog pump manufacturer and see if they have any recommendations on measureing the vacuum draw and where to do it accurately. It is now installed by the way.
  11. #911
    10,788
    Looking good!
  12. #912
    Thanks Craig, a long way to go still.
  13. #913
    Still making progress
  14. #914
    Looks like you have plenty of room to work!!!!
  15. #915
    I like to keep it as clean and organized as much as possible Brian.
  16. #916
    Aug 2007
    In a Van By the River !!!
    4,671
    That's a really pretty Green Shayne !!!
    Looks Good ...
  17. #917
    That thing would look badass if it was dark metallic gunmetal!
  18. #918
    Or even a shade of primer!
  19. #919
    10,788
    DUDE!! I feel your pain with the Fuggin Bikes!!!!!
  20. #920
    That's for sure! Just had to replace both inner tubes on my daughters, rear tire and inner tube on my sons and the rear inner tube on mine, what the heck!
There are currently 21 users browsing this thread. (0 members and 21 guests)
