Page 29 of 42 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 834
Thread: Before & After
  1. #561
    Jul 2015
    452
    I was thinking you said all motor. But if you will give me the bottle.....
    #2 - 2020 DD Challenge List
    1997 Cobra - C heads, Cams, Sullivan intake, long tubes, homemade cai, 4.30, strange axles, e85, chromoly cage
    2000 Saleen S281SC - factory "stock"
  2. #562
    Aug 2007
    In a Van By the River !!!
    4,672
    I already gave the trans away.
    I was talking about the car !!!
  3. #563
    Quote Originally Posted by S281SC View Post
    We can run it both ways!
  4. #564
    Jul 2015
    452
    Yeah i would probably still have trouble with your coupe... maybe i need bigger pills...
    Craig has me nervous with this tko issue though. I have been running mine low 11s for 3 years and it hasnt skipped a beat. I leave around 5k. I wonder if the clutch is the difference? I have a ram 900 series disk and a light flywheel and the lowest non adjustable pressure plate that ram offers for my car. The 900 series disk slips when its cold but gets grabby as it heats up. The theory is a little slip on the line but holds power on the big end. I think it is basically the metallic friction side of the ram hd on both faces instead of just one side of the hd clutch. For my little engine with a little spray it works really well. I will have to see what more power does to my poor tranny and clutch though...
  5. #565
    Application of power via operator and or clutch are the biggest factors of failure.
  6. #566
    Aug 2007
    4,672
    ^^^ This !!!
  7. #567
    10,793
    6800 and Drop the hammer!! I still dont see how a Spec Stage 2+ killed this mofo.
  8. #568
    8,348
    I’ve been running a spec stage 1 behind my 2V and then the coyote and while it smells awful I think the little bit slip has kept the transmission alive.
    They who can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. - Ben Franklin
    1998 Mustang GT
    Coyote Swapped
  9. #569
    Application of power via operator LOL
  10. #570
    10,793
    Got the trans install started last night. Dropped off the New slip yoke and old DS to get shortened up and re-balanced this am, then back to work this am. Pheew, Im getting too old for this shit.
    Im thinking this is going to be the last manual trans I install, so hopefully it lasts a while.
    This trans jack from HF, works pretty well. It rolls around smoothly and adjusts easily with a 1/2 drive.
    New Stifflers cross-member installed and the trans is IN! I will be running a Tilton external oil pump to push oil straight to the main gear assembly via a -6 line (trans already had the hole where it needed to be) so ill need to fab up a mount and another micro switch. Im thinking Ill have it activated with a WOT micro switch, but then Ill also have to come up with a Neutral safety switch.
    A few other wires to splice, install the DS (ready next week) add fluid, mount the shifter, install exhaust, then take it out and see if I can break this one as well...Joys of a stick car.
  11. #571
    Looks great!!!
  12. #572
    REALLY hoping this one stays together for ya!
  13. #573
    10,793
    Me too. I want to keep it a stick car, but Damn, if its only going to last 7 hits, then I have to change something.
  14. #574
    10,793
    My Kindergarten education for using scissors came in handy last night! I needed to make a mount for my trans/diff pump, so I grabbed some cardboard to make a template and went to work!
    Hopefully, next week, my DS will be ready so that I can get this back on the road. I think Ill leave the slicks off for awhile so that I can enjoy driving this and be able to put some miles on it. This breakin shit is getting old!
  15. #575
    Enjoy it
  16. #576
    10,793
    Wow was it HOT in the garage this weekend! I managed to get the pump mounted and started on the wiring under the dash.
    Im no metal worker, but I think it turned out fine.
    I screwed up and mis-marked the holes, so thats why the 2 are bigger.
    Ill wrap the collector with some Heat Wrap to help keep the pump alive, and maybe make a heat shield for it.
    Hopefully, my DS will be finished this week and I can get this back on the road. Im keeping the slicks off of it till I get the Tamer figured out, breaking shit is getting old and expensive.
  17. #577
    8,348
    What’s the pump for?
    1998 Mustang GT
    Coyote Swapped
  18. #578
    10,793
    Quote Originally Posted by cstreu1026 View Post
    Under WOT, the pump will send oil straight to the main shaft/gears via a -6 Hole. Some of the Higher HP guys are doing this, so I figured since I can break anything, Ill take all the extra precautions that I can get! LoL!
  19. #579
    10,793
    HOPEFULLY, fingers crossed, Ill be firing up this back up tonight. I have a buddy coming over tonight to help me with bleeding the TOB and installing the exhaust. When thats done, its time to hit the switch and go for a ride. Im curious to see the difference in the 5 speed vs 6 speed. NO slicks will be on this until I get some miles on the Magnum and get the Tamer figured out. Hell, Ill probably just wash this season and just drive it on the street.
    Forgot my cutters the other night, so I went old school...
    BAM!!!
    Im REALLY hoping I can figure this shit out as I WANT to keep this a 3 pedal Stang. It would be too easy to slap a PG in this, but Fuck all that. Manpedal FTW!!!
    Wish me luck...
  20. #580
    It actually looks like it may work, let me know.
There are currently 4 users browsing this thread. (0 members and 4 guests)
